well, since I used full-size axles the measurements will be different....
also depends on the leaf springs you use....length and what-not...and how much lift ya want....
also, CJ axles have a passenger-side drop pumpkin up front....have you accounted for comeing up with a different transfer-case to make up for that??
I know they are free, but changing your drive line to compensate for the different drop may be more expensive in the long run....not to mention CJ axles are notoriously weak for actual wheelin'...
what size tire do you wish to run???
what type of wheelin' do you like to do, or no wheelin' at all???
are you willing to trim ya fenders, do you still want it street legal (depends on the state you live in, I see your in TN wich is pretty lax in the legal dept., but saying in general for others that may read this) ???
those are all questions ya need to ask yourself first....then ask others if you are unsure....but, you will get a variety of opinions on that subject ( cause of course different regions need different style 4x4's )....
hope that helps ya a little....
l8r, John
