Leaf spring lean, bumpy ride
twfmvm
I have a 92 ranger with four new shocks installed about five months ago. it appears the right rear leaf spring is lower.
on flat ground i measured 3" from top of tire to body on all the other sides, this side is only 2.5".
Now my question is would this cause a noticable change in ride harshness? Not too concerned about putting ridiculously heavy stuff in the back.
Id like to add that when i drive the vehicle over bumps it appears the front end sinks more before springing up. It feels like the ( front ) coil springs compress more than they should, causing an initial 'bounce' which smooths out quickly because of the new shocks, but can quickly feel like a bouncy house on rough roads.
My second question is would it be better to replace the front coils or rear leafs? what would yall do to improve ride quality
My expo has that same feeling on the front end and I replaced my shocks about 4 or 5 months ago as well. For the front end I would replace the coils. Mine feel really worn out like they are losing their stiffness.
For the rear end it's hard for me to say because on my ranger I don't run a bed on it and my leafs are visibly bent but it rides smooth but I don't have very much bump travel to accomadate for larger bumps.
If it were me, I would replace the coils, give it a month or two to break in, then if you feel like the leafs need to replace then you can replace them.
Sent from my LGMS345 using Tapatalk
Yeah, thats kinda what i thought. I feel like the front springs would be taking the most of the weight/bounce in most pickup truck with an empty bed.
Im still wondering though if 3 springs are level and one isnt wouldnt it cause vibrations/bouncing regardless? Like a chair with a short leg?
Sent from my SAMSUNG-SM-G890A using Tapatalk
I wouldn't think so. Especially only being off by about .5 inch on what I assume is the drivers side which has the added weight of the fuel tank.
Didnt think about fuel but its the passenger side
