Leaf spring hanger replacement.
ended up ordering through stengal bros, the kit (which includes hardware!) and bushings with shipping ran me just under 150. and its out of pennsylvania which is much closr then kansas (lmc) probly get them sat or mon. (i went with ups, no need to spend more to overnight them) probly get started on it next week sometime, might buy some liquid bedliner to coat the peices in before i bolt them on. if i had went with L.M.C. it would have ben about 275
still waiting on my package from ups to arrive, in the meantime i did something about my rust-holes in the tailgate & bumper. im no body-man, but at least its better than it was before.
Just replaced my rear shackles and hangers. Inspection mechanic would not let them by this past Saturday. I paid around $30 for each piece (2 shackles and 2 hangers) from the stealership. Where they got to me was for the shackle bolts. $11.50 a piece, the parts guy asked me if I needed the nuts too. $11.50 for a bolt and they don't come with a nut? They wanted $6.50 for the nuts. I did wind up using 2 of their bolts and one nut because I was pressed for time. I have a set of torches that made removal of the rivets quick and easy. My bill from the stealership was $160 in the end.
got it done today. started at 11, was putting tools away by 5:30. a torch is defintly helpful. while pulling the bed may help, i didnt want to go to that extreme, thats 4-6 more (major) fasteners, i had no help, and as badly rusted as things are under my rig, it would just be more time spent than i felt was worth. first thing i did was get the but up in the air, just as high as my jackstands would go. i pulled both rear tires and put the jack under the differential. unbolted the lower shock mounts, pulled the exhaust pipe out of the muffler. (i just put a new exhaust on it a few weeks back and used anti-seize on the joints, wasnt a problem) tried taking off the bolts holding the shackle to the spring, right side nut came off, left side just turned and collaped the rotting shackle. took the torch to the left side nut at the spring/shackle. torched off all the rivit heads. on the left side of my truck the back 2 (up and down) were bolts, torched them also. torched off the shackle where it meets the spring, lowered the rear axle with the floor jack as much as possible (rear brake line limits you here) took a hammer and chisel to the edge of the old brackets to seperate them from the frame. was able to knock rivits/bolts out o.k. on left side, right side only 1 would knock out, fired up the torch again and burnt them out. for removal of the spring bushings from the spring, i heated it up good with a torch, put the impact gun to the remaining bolt head and just kept at the trigger, it worked itself out, pried out the rubber from the spring eye with a screwdriver. putting the new bushings in was super easy. clean the spring eye, get some all-thread with nuts/washers.(you want it to just fit through the bushing) pass the all-thread thru the bushing & spring eye, put on bolts/washers, a little anti-seize for thread lubrication and i also lightly coated the bushing. the spring eyes were still warm from the torch, im sure this helped a bit. ratchet on one end of your all-thread, wrench on the other. and just "draw" it together. i cleaned the frame and sprayed on some areosol truck bed liner (i did my brackets and shackles the night before also) let it dry while i was putting the torch and air compressor away. put on the brackets, attached the spring to the shackle. hooked up my shocks and exhaust, tires back on, jackstands out, tightend wheels and hooked up diff vent tube (i had forgot about it when lowering the axle, it simply pulled out of the sot in the bed rib where it had been stuck) put tools away and headed home. (i did this at my folks farm, most of my tools are there, theres a nice slab of concrete to work on, and most of all dads torch! thres no room for a grinder) i didnt take the camera with me and its rather pointless to show you the new parts on. i did take pics of the old shackles after i removed them, they were much worse than i thought. the heating and banging really loosened more rust. got to do dads '94 3/4 ton next, the r.s. on it has seperated completely. one thing i found odd, on the 3/4 ton fords its basically the same bracketry (just bigger) but its installed upside down! (compared to how its on a ranger) heres the pics of the old junk once removed, 2 are of the left side and the last is of the right. wouldnt have made it another year!
1-888-9GETATS. All 4 hangers, 2 shackles, bushings installed, and all the mounting hardware 199.95 free shipping.
Just to let everyone know, I got my hangars from Mikes Truck Salvage. This guy is awesome. He runs the business from his home and all his parts are rust free and still shinky. My hangars are like new. I got both back shipped to my house for $60 and I got one front one 3 days ago shipped for $25. They come with everything except the bolts that go to the frame. They have the big spring bolt. I would rather give my money to the little guy instead of big business anyday. His website is www.mikestrucksalvage.net and phone is 846-861-2044. He carries all ford parts from little stuff to complete trucks. This was my first post but I just wanted to let you guys know how to save some money and help out a smaller business. Thanks
Why does everyone go through so much for these hangers? They're only $23 each at the dealer. And O'Rielly's has the Belltechs in stock for $30.
For my 92 they were $160 just for the back at the dealer here in WV.
i did this common repair to my dad's '94 F250 a few weeks ago, used a air chisel instead of the torch this time due to it having a rear fuel tank. went pretty well.
I just bought some yesterday on ebay, 43 a side for the rear hanger, shackle and bolts. 102.00 shipped to my door.
It looks like the rear spring hangars are the same from '89 to '09. I'm assuming that there is no difference between standard and extended cab one's as well. I noticed today that my right side is broken and I'm going to do the left one as well while I'm at it.
all the pictures of the ones above were no where near as bad as mine. but i did mine with the bed on and used a torch to get the tops cherry red then too an air chisel to the heads. it took maybe an hour to do at the most
