Is it possible to replace the LCA bushings without removing the shock, sway bar arm etc? Will the LCA drop enough to replace the bushings after removing the bushing bolts?
Thx
Jim
2000 XLT 4X4
You will have to remove the torsion bars to get the lower control arms out to replace those bushings so you will have to have all the other stuff off anyways.
I was hoping to release the torsion bar and simply drop the control arm down enough to replace the LCA bushings. Can this be done without complete disassembly of the LCA? Why must I remove eveything else?
For
