curtis73
94 B4000 4x4/M5OD 104k miles.
I have a bunch of dumb stuff that is going to require taking the Fordzda to the shop. I've been working 70 hour weeks and I'm currently without garage space (and it's bloody cold here). I thought I'd run some of these problems by you folks in case you have ideas that I can pass along to my buddy at the shop to narrow down some diagnoses.
- The truck has an intermittent no start/rough idle issue. It happened about 4 times this past summer, but each time I could get it to recover with some gentle throttle input. Then this past August it let me sit hardcore. Hot day, went in to a restaurant for a meal, came out, and it would start but idle really rough at 350 rpms. Each successive start it would run rougher and die sooner. Under the hood I checked the obvious stuff. The first thing I suspected was fuel pump. When I pressed the Schrader valve on the fuel rail, I got vapor. Yes. Vapor for about one second, then fuel. Got back in and cycled the key a few times, still crank/no start. Re-tested for fuel at the valve and had liquid fuel. Relieved all the pressure from the valve, (that was a mess) cycled the key, checked the valve again and had liquid pressure. No idea how much, but there was fuel. No start. I towed it to my shop where of course it magically ran perfectly the next morning. I started carrying my fuel pressure gauge in case it happened again. It happened again tonight. Drove 20 miles with no issues, stopped at the store for a 6-pack, came out, rough idle and died. Tried again, same thing. I popped the hood and put my pressure gauge on, turned the key, the gauge popped up to [couldn't see] pressure... and started and ran fine, so whatever the problem was I may have missed it. All of the times it happened before it was summer and hot. Tonight it is 21F. I checked for fuel in the vacuum line from the FPR and found none. I also pulled the IAC and it looks recent and clean (but doesn't guarantee it's working right). I pulled the intake bellows and the TB doesn't look nasty; just a few traces of junk.
- Possibly related; 16 mpg down from a normal 18 mpg, but that could be winter blend fuel.
- Also possibly related, intermittent misfire that is very minor. I can tell at a stop because I can feel a little shake in the truck and the shifter has a little shake in my hand. Most people wouldn't notice, but I'm a gearhead. This misfire is more often happening than not. When it's not happening, it feels like SDS (sudden Cadillac syndrome) and it accelerates better. It seems like for 15 minutes each week, the stars align and it runs like it's supposed to, but the rest of the time there is that teeny misfire and slightly down on power.
- Steering is strange. It is loose, which could just be the steering box, but follow me on this: Let's say I'm getting on a highway with a 270-degree onramp. I enter the ramp and turn the wheel about 90 degrees. When I go to straighten out, it feels like the wheel is almost stuck at 90 degrees. As I go to return the wheel to straight, it feels like someone was under the hood holding the steering shaft until I started to reduce steering angle. U-joint in the steering shaft? Rag joint? Stuck valve in the box?
- Other steering issue. Manual front hubs. If I have the hubs engaged but still in 2wd, the problem in #4 is more noticeable. Things like slow parking lot turns I can feel the steering kick back a bit as I return the wheel to center. It is almost the same feeling as turning while in 4wd, but the opposite. In 4wd, the steering kickback gets greater as you turn harder. In this case, it turns fine, but as you start to re-center the wheel, it kinda pulses back to center. Tire pressures are all correct.
