Largest Tire with 3" body lift
JeAlPu
I was wondering if anyone knew what the largest tire I could put onto my '96 Ranger Super Cab 4x4. It has a 3" body lift. Right now I have 31x10.5 Kuhmo Road Venture MT on the stock 15x7 rim. I want to know if I can go a little bigger with out having to trim anything. Thanks!!
You should be able to go to 33s atleast i have a 05 fx4 level 2 stock right now with 33's on it and they run fine
you can go 33 but it will most likely rub on the sway bar you could get coil spacers or 2 inch lift coils to solve that problem and shackles in the back to keep it level. but you can run 33s if you can deal with a little rubbing. im not saying 100% that it will rub but theres a pretty good chance they will
Well with the 3" body lift thats a solid 3"s no flexing down or anything. I think 33's will fit, but get some 8" wide rims too with stock back spacing and that should stop the rubbing on the sway bars.
I have a six inch lift on a 95 4x4 Super cab and my 33's are about a quater inch from rubbing the back of the fender when I turn, and they will hit at full stuff if I have the wheel turned. I am running 15x8's with 3.75 backspace. They will rub the RA at full lock as well. I dont have a stock bumper, but I am almost certian that a stock bumper would need to be trimmed.
You see that if I turn the tire will hit.
-plumcrazy
Thanks every one!! what about 32's do you think i will fine with them? and does anyone know what the widest tire you can fit on a 15X7 rim is?
with a 2inch spacer you should be able to fit 32's. im pretty sure thats the set up Tbars was running up front with his 32's
