bobbywalter
Ugly Truck of Month
TRS 25th Anniversary
- Aug 9, 2007
- woodhaven mi
- Automatic
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
That is a lower ball joint. No vehicle built in the last 50 years has used king pins.
Do both the upper and lower as it is a lot of work to get in there compared to the extra work to do both joints while you are already there.
Most of the needed tools can be rented at a local parts store for less than the cost of labor, but you will need an alignment when you are done. It's not a hard job, if you are at all mechanically inclined. I did mine in about an hour a few months ago. I had air and all the right tools already in hand though. Working at home with hand tools expect it to take 3 or 4.
mmmm. 50 years? there were quite a few king pin ford tib trucks, if you ever have to replace a set of siezed ones you will never forget it....i hated them damn things. hours upon hours with a rosebud and 20 pound hammer i will never get back...
my ranger has kingpins as well.....of course its axle is older then you....but it certainly has king pins.
dana 25-27-30-44-60-70 all had king pin versions. many even closed knuckle...most newer then 50 years.
Can I use Dana 28 Ball joints in a Dana 35?
no.....totally different.
