killing an auto
swynx
lewiston idaho
gf has a 2001 chevy cavalier, when she takes it out of park and puts it in any gear, it just dies, its done it about 5 times in the last month, but it doesnt always do it, doesnt matter if its hot or cold. i was thinkin it was cuz she stepped on the gas but its not. so any ideas
Sounds like it could be an idle issue? I had a similar problem with a carbureted car.
lol the tranny is over full on fluid and yes its a chevy. but it seems like its more of an idle issue but it only does it once in a blue moon
Well, cavs dont usually last much longer than 100k before they take a shit on your wallet and leave you stinkin broke and walking...When is the last time she had a tune up? Spark plugs, wires, maybe even a new timingbelt/chain....Id try that first...and adjust the idle while you're at it...then sell it and buy a honda or nissan if she really want a lil car.
Either 1- an IAC (idle air control) or 2- Torque converter lockup solenoid, locking the torque converter as soon as it goes in gear, doing the same thing as dropping a clutch at idle.
I would pull the IAC off first and clean it out with throttle body cleaner (DO NOT use Carb or brake cleaner, it will wear away the special coatings) and a lil WD40 never hurt either. If that doesnt take care of it it might be a trans problem.
later,
Dustin
well she just got the car about 2 months ago and still owes 4800 on it, i changed the spark plugs about a month ago bcuz i pulled all 4 and they were all burnt up, and black, never looked like any plug i ever seen. and ive never worked on something this new before so itd have to go to the shop
later,
Dustin
the trans is over full and has been its like 2 quarts to full
