Kerry Meadows
kmead272
I am new to Ranger Station forum however I have read the Q&A's before. I have a 94 Ranger 2.3 4 cylinder 5 speed. Before it was spitting and sputtering, took it to Quick Lane of ford in Decatur Alabama and the mechanic diagnosed check engine light gave codes to replace and we did for MAF, EGR, TPS, COIL PACK, PLUGS, DPFE FUEL REGULATOR. Did that and for most part it fixed the sputtering, well now in each gear I get a hiccup in gas pedal and if I try to floor it it peters out no O2 sensor and no code for catalytic. Thought maybe transmission but had clutch kit and rear main seal throw out bearing and pilot bearing and slave cylinder replaced. Also replaced EGR and cleaned ports throttle body and intake with toothbrush. Ford mechanic did all of this. Stopped up injector or IACv? I Please help.
