keep the back flass
86MUDRCJ
Sheridan, CA
I kinda want to the slider back window in. How easy is it to do? And would it be better to order it from lmc or get it from a jy?
It's easy to do with a pliable gasket. I put one in my truck ages ago, it was new. You might be able to find a good one at the jy. I did rebuild one that is in my camper shell.
:beer:
Rich
Is it so easy a caveman can do it? If it is then ill give it a shot.
Easy. Pull the trim panels from the inside and that'll expose the few bolts that hold the window in.
no nuts on a regular cab, open the door, push out on the top corner until you can get your fingers behind the seal then start pulling, work your way across the top then down the sides and pull up on the whole window. Install is basically the reverse, set it in on the bottom or one side and work the seal in around the ledge. It's a little more difficult with a full interior but my truck didn't come with one :)
ok, now i have a question, what years will interchange, i know 83-92 will, what about 93+?
it has to be a regular cab, but I believe they work through '98 as I've noticed they still have that tiny rear window, I wish they had the large extended cab size...
