THE WINCH MODIFICATION
Getting an angle off the bed.......
Transferring the angle to the 2" square tubing......
One end of the tubing is cut........
The other end is cut from the 8' tube...I even managed to match the cuts...
The bar is in place and ready to be drilled for the bolts........
All the mounting bolts have been drilled...the bar is bolted to the bed....the winch is temporarily mounted to the bar.....
If this Loo-z-anna weather clears up for 24 hrs.....I'll paint the mounting bar & the winch........
Well......finally got back to the winch mod...the winch motor has lost it's camoflauge paint........
the 2" square tubing has some color too.......................
here it is assembled.........................wiring needs to be run which means a trip to the auto parts store for a quick-disconnect for the winch...
pics later when the wiring is finished........maybe the weather will be good enuff to winch the Harley onto/into the bed.............
the quick disconnect wiring is finished & I used the remote control to roll out the cable/roll it back in......
I'll be able to connect the cable eye to the Harley swingarm--I'll sit on the bike & use the remote to pull the bike onto the bed of the truck as I guide it up the ramp......MAYBE TOMORROW !?!?!?!?!?!
FRIDAY UPDATE: The winch had to be turned 90* to get the cable to wind up without piling up in one spot....Now it works like it's supposed to...
Here's the Harley with the winch cable attached to the swingarm..........
(I couldn't take pics & ride the bike up the ramp at the same time.....so the next pic is the bike loaded onto the bed........
I'll air up the rear shocks tomorrow & level the truck..........
