Just Plain Stupied
*****2022 EDIT...SINCE PHOTOBUCKET DELETED ALL MY PICS I AM REPOSTING MORE PICS******
Sub Thread...2.9L to SBC Engine Swap continued
Now I understand why a 1/4" thick flat adapter plate needs to be made to "move" the passenger's motor mount 3" forward on the engine crossmember.....
My mistake!!!.....Adapter plate needs to be 7" x 7" instead of 6" x 6".....It's a good thing the guys told me about fabricating a plate............
Just Plain  Stupied
Just Plain  Stupied
The driver's side motor mount is about 5/8" rearward on the crossmember.....close enough for me....but I will need to trim about 3/8" off the top front corner of the motor mount next to the steering rag-joint for clearance.....
Mounting holes have been drilled thru adapter plate wwith a 14" long drill(bit) using OEM x-member motor mount holes as guides for the 2 new holes in the adapter plate/bolts have been put in & wrencFriday!!!...Alright.......let's do the easiest thing first til the meds wear off....
the drivers side Block-Hugger Header needs 1/2" clearance at the engine x-member & at the top of the frame rail......probably 30 minutes of trimming metal.....
Just Plain  Stupied
I ended up removing the top corner of the clamshell to give the front tube of the header 3/4" clearance & removed 1/2" off the top of the framerail to give 1" clearance at the 2 middle tubes.....
Now I don't need 5 hands & a pry-bar...the header drops into place!!!
Just Plain  Stupied
Back to the go-rajjjjj......Time to move the pwer steering pump up a few inches.....
Good news...I only have to move it up 2"...if I cut out the piece of bracket painted white....I can reposition the pump to clear the adjusting nut/screw on the steering housing....
Annnnd....since the '36 Ranger grill is 2 feet narrower (RangerSportHonduras hates when I say that!) I will also be able to get the large steering-pump pulley inside the left-side engine cowl......
Just Plain  Stupied
1 hour later......accessory bracket is removed & cuts are made........
Just Plain  Stupied
Just Plain  Stupied
Back to the go-rajjjj...... slap it all back together......sitck the pump in place.....& if it all fits....:icon_welder:....more picks in an hour....
It fits!.....here's a couple pics of the complteted modification....
Just Plain  Stupied
Just Plain  Stupied
back to the go-rajjj.....fan is on....serpentine is on.....radiator is on....gallon of gas is connected to carb....guess what's gettin cranked up first thang in the morning........
OOOOPs....since I mis-placed the smog pump...so I added an idler pulley in place of it (until I pick up another pump) to get the right tension on the nearly new serpentine belt instead of buying a shorter belt...
Just Plain  Stupied
Just Plain  Stupied
:icon_surprised:
It runnnnnnnnnnnnnnnnns!......It runnnnnnnnnnnnnns!........tomorrow...exhaust hook-up/modifications!!!!!!!....might even do the driveshaft hybridization with a Chevy yoke on the xmsn end///Ford U-Joint on the tail end (did too much road-runnin for Precious today to git anything accomplished/maybe she won't find this)......
REDTI: The first video downloaded for an hour!!!but wouldn't play.....:annoyed:....I tried again in the dark & got some good flame shots outta the headers, but the computer sayyyyyyyed it wasn't compatable with the camera :mad:
Sunday...
I'm just laying back todaay.....I bought a pressure regulator (but everybody was sold out of "return style" reg's)....I bought a few brass fittings and made a return port with a internal pressure reducer (the cone-shaped piece) that will fit inside the return line to the tank.
Just Plain  Stupied
The left side of the Reg. is the carb side....The top right fitting is for the OEM '89Ranger electric fuel pump line...the cone fitting is for the tank-return line...
The tank plumbing is done to & from the carb......pressure guage.......inline clear fuel filter.....regulator.....
I drilled thru the cone shaped brass plug and pressurized the fuel system...a .040 drill(bit) wasn't large enough/it still had 50 lbs. of pressure...
It took 2 more times with larger drills each time to get the pressure to 8psi at the guage(carb fitting) .060" diameter I think?
Just Plain  Stupied
The wiring gave me 3 headaches at one time......so I'm going to do the driveshaft....cutting the rivets off to remove the d-shaft support brace....
Just Plain  Stupied
Looks like I've got to lengthen the sbc shaft about 15".....
I used a radiator clamp as a guide to cut the driveshafts (I measured from the fixed u-joint eyes & tightened the hoseclamp in place to make the cut....
Just Plain  Stupied
I measured how much OEM ranger shaft i needed and added 6" to that length (the 6" extra will slide into the larger sbc shaft until I have 65" total from the SBC xmsn end u-joint to the OEM Ranger add-on tail-section u-joint....
Just Plain  Stupied
Just Plain  Stupied
Continued...........................maybe reposting all the deleted pics won't take 6 months...Waaaaaaaaaaaaaahahahahahahahahaha...
Carry on man an you will get her knocked out in oh bout ehhh 7 days
drive shaft install etc goes here
I love the atv winch/engine hoist
It's rated at 3,000 lbs.....it was picking up the front end of the truck until I realized the motor mount studs were catching on the engine mounts...guh-huk-guh -huk.....
annnnnd.....You younger guys need to take notice of the details when doing a V-8 swap.....see if you can spot the improvement...
You forgot to take out the v6 mounts LOL! :icon_thumby:
Looking good, sucks you put so much time into that 2.9L only to rip it out again. But that makes two of us (I pulled a 2.9L I had rebuilt in favor of a V8).
Pete
wow u just finished the build and u taking it apart!!!
i think that any chevy flaming wont do anything good, so i wish u luck!!! hope u can get it done soon!!
i just wish it was a ford v8...:D
I didn't ferget....I'm gonna use then on the sbc !!!!!!!!!!!!!
Pete
Looks nice DG. I like the "any reason to paint and sound deaden" attitude you got. Just like I think; If you're gonna do it you mind as well go that extra step above:D.
Ya see? Now doesn't that engine bay look better with that beefy v8 in there? :) Coming along nice, mate.
Your neigbors are probly woundering whats he doing now?? I think with the V8 weight in there it'll bring the front finders right down over the tires and give it a good stance.:icon_thumby: Looks great DG sorry I don't get around here much any more but I try to check in as much as possible I'll half to put ya back up for Truck of the month again next year withj the SBC swap and all LOL!!!!
thanks men.....now I gonna eyeball the engine to see if I'm gonna have a red distributor sticking thru the angled floorboard of the cab!!!!!!!!
Waaaaaaaaaaahahahahahaha
That would actually be pretty badass...it's not like it would really clash with the color scheme you've got going on.
Completely true!!!!!!!!!!!!!:icon_rofl:
