Just Plain Stupied
To be honest I just want to check our his VA Edition crock sandals.
Lol. Right on. I bet they are real nice. Gubment issued stuff is always high priced, so they must be nice.
Sent from my Quad Core Acer A210
Well post some pics and take your thread back, good sir!
O-O-O-O-O-O-O-K-K-K-K-K.........................
My new lifetime alternator.....................
Just Plain  Stupied
Bolted in & connecting wiring....................
Just Plain  Stupied
New battry behind passenger's seat under floorboard.....................
Just Plain  Stupied
Fried accessory outlet....fried assorted wiring from under dash.....(should have installed a relay to the On/Off switch for the transmission overdrive solenoid---duhhhh).....
Just Plain  Stupied
Now....need to finish wiring to heater blower and the radio................
Alternator is rewired with heavier wires....
Fried dash wires are repaired...........
A/C & heater wires reconnected to proper OEM wires & fuses....
Everything works great....no more drop in voltage when lites/cooling fan comes on....
Engine cranks much faster/better now!
3 hour test run.....O.K. :yahoo:
(now to cut out unused ratnest wires under dash)
Broke a motor mount weld/didn't get the weld hot enough to penetrate enough.......now I know where that slightly noticeable cab vibration is coming from!
Gonna get to see you pull the motor out again? This gets better and better!
How do you spell "Uhhhhhhhhh-uhhhhhhhhhha" (as in "No Way")
I gonna jack the engine up an inch or too on the broke side....
unbolt the mount from the motor & the frame.....
weld it up right this time....
reinstall same.....
:yahoo:
(will take pics)
reinstall same.....
:yahoo:
(will take pics)
You old people and your practicality...ruining all the fun!
annnnnnnnnd they drive with both hands on the wheel (not cause they've lived long enough to know that it's safe----they just think they're NASCAR drivers)
and they got funny lookin eyes too........
Just Plain  Stupied
compare eyes..........
Just Plain  Stupied
and they fall asleep anywhere waiting on truk parts to arrive......
Just Plain  Stupied
annnnnnnnnd they're ornery.................
Just Plain  Stupied
I finally got to the broken weld on the passenger side motor mount brace....
Just Plain  Stupied
the big thing on the left is the 02 sensor......the crack is to the right---seems like when I was mocking up the engine mounts---I just put one bead there in case I needed to grind the bracket aloose to re-adjust the engine... :icon_bounceblue:
the other thing that I took a chance on was the drain plug in the torque converter....
Just Plain  Stupied
there was only 1/4" of space between the inside wall of the converter and the housing of the lock-out clutch..... :icon_surprised:
once the drill went into the converter I used a small magnet to remove the metal chips from drilling and tapping for the 1/8" pipe plug....it was fun when all that transmission fluid poured onto the drill "bit"......ssssppppprrrraaayyyyyy!
