parashootist
Just got home from picking up a '97 Aerostar XLT 4.0L AWD with the 5r44e.
The van was listed as having a rough idle and the seller said it likely needed a fuel pump, had low cylinder pressure (I think he meant compression) or something else.
Despite having sat for a year or so it fired right up and sounded okay. When put into drive the vehicle felt like it was vibrating/shuddering. I took it for a spiny around the block and it seemed to run fine. Horrible rattle from a heat shield or something underneath and then what I suspect is a transmission issue versus what the seller felt it was. I suppose there could be multiple issues.
What should I start with? I picked up a couple jugs of Maxlife on the way home. I'm thinking I'll order a filter and drop the pan. The fluid on the dipstick didn't look red.
Thanks! (I do also have a Ranger in the driveway)
