Stuntman Mike
- Jun 16, 2008
Just got a 94. Misfiring issue, currently trying to solve. (Signs pointing to EGR)
I know, first thing is "check the codes!".. but it's been about 20 degrees out and I suspect the previous owner painted over/disconnected the CEL.
So here's the situation. Starts right up fine and runs fine for maybe a minute. Then it misses like a cylinder is completely dead for a minute or two. Then after it runs full power and doesn't miss a beat until shut off again. It more or less had the same pattern when it was 50 degrees out, so I don't think it's related to the outside temp.
Without checking codes (I will eventually when it's warmer, don't yell at me.) can anyone guess what would cause this behavior? I'm leaning towards a sensor issue. Like the computer after warmup sees the readings are fubar and goes back to open loop.
94 2.3 5speed.
94 2.3 5speed.
