Just bought an 84 Ranger 5.0
we need a burnout pic now :p
as soon as i finish the wiring, get a carb, rebuild the trans, put in the driveshaft, ill get one :)
Well i threw my battery and a edelbrock 4-barrel carb in my truck, just to see what it would do, and it cranked a couple times, and started, but didnt run long, since i dont have the alternator wired up yet, but still, been sitting in storage for 9 years, and started right up.....gotta love a ford :)
^plus it sounds BEASTLY true dual 2-1/2 inch aluminum pipes with bullet style mufflers straight out the back, sounds like our hot rod :D im stoked!!
um if its from a ford svo mustang it orginally had a smaller input shaft did he change them out? if he did yes it will stand up to v8
yea he said he changed the shaft and it worked fine against a 289 he had in it before the 302, he said it would leave some mean one wheel peels lol
i have the part # for the pilot bushing you can use to keep from having to replace the input shaft.
It's been awhile but here's an update on the build. Yesterday I took the T5 out in about half an hour. I will be rebuilding it soon, I'm saving up some cash for the rebuild kit. I already have the T5 rebuild book, so me and my dad are gonna take a crack at it. If everything goes as planned, I should have a built up running 302 Ranger by July-August :)
(As you can see, I left the bellhousing in, since its a wet-clutch, I didn't want to mess with all that just yet.)
There's my dad inspecting the T5, I owe my car craziness to him
Sssssssssswwwwwwwwwwwwwwwwwwwweeeeeeeeeeeeeeeeeeeeeeeetttttttttttttttttttt
If your gonna post, don't be the only negative 1 in the thread
LOL, man, you really need to make some room on that work bench!
I think I would be spending more time trying to find what I just set down, than I would actually getting anything done... But I am notorious for setting stuff down in places I tend to never look.
Pete
When you mechanic... things get messy. We moved out of a 2 car garage, to a 50x60 ft building and still filled it up.... we just bought a bigger welder, and got more cars and trucks. LOL
Frank
Frank
Hell yeah things get messy. But I got pissed off at how much time I was wasting by not taking 5-10 minutes to clean up after working on something before I go in and call it a night. Some days I actually spend only cleaning my tools, pick up power tools and put them in their boxes, throw stuff away, etc.
I just moved out of a house w/ a 2 car garage into a house w/ a 3 and it's a cluttered mess, it drives me nuts. I set something down and it took me like 5 minutes to finally find it again. :D
Pete
Yea I'm not to worried about the garage....it's a working mans garage, some truly beastly creations are born in there :)
yes he said he changed the input shafts out. And the trans is from an 84 Ford SVO Mustang
Well, another update for yall. I found out why the T5 wasnt shifting. in the shifter yoke, there is a ball bearing and a spring in the shifter holding it down. The ball bearing wasnt in the groove that it was suppposed to be in, so the shifter would bind up. So thats fixed, it shifts now, so ill be cleaning the inside, putting in new oil in the trans, new gaskets and itll be back in and running :) and in the meantime, heres some update pics of the truck
New bumper
Cleaned up under the hood a bit....BTW the underhood color is "Corvette Blue"
Pretty Close
frame was slightly notched for clearance
Brand New 4-Core Radiator
shifters just sitting there, the trans is still out
Ok i ordered the part i needed for my T5 from a Ford Dealership, so the beast should be roaring down my road pretty soon
