Just another 2nd gen explorer SAS
6-7"s of lift est.
Coil buckets were from a 79f150
Coils are deaver superflex, 5.5 lift but they will get cut down to fit. Plan is to drive it under my 6'10 garage door...
I'm hip, and thanks for the information. I'm looking forward to watching this build!
Mocked the radius arm mounts into place, now just need to mock the gear in position and cycle the susp and see how things fit and work.
On its own weight, no jackstands. Far from finished. Everything is just barely installed to check clearances and such. But this how it'll look. The floor isn't quite level due to the drain.
Sexy. Hope it'll make it out the door when your done lol
Don't worry, he knows a guy that can do roofing work when he cuts the roof to get it out :D
SVT
Full stuff drivers side, about 2"s further then what I will allow after a bumpstop install, RF drooped as far out, wheel turned to lock left side. Over and 1" of clearance to the body. Slight rub on radius arm.
Little bit or radiator and condenser protection, 3/8" angle.
Working on the gear box install.
backside
lower coil mount
Steering shaft made, not sure how well this is gonna work.
Ozziemoe burning the radius arm mounts in place. This guy does some damn nice welding, better then myself.
Radius arm mount
Sitting on it own
2 bad ass fords
Spent about 9 hrs in the shop today busting ass on this thing. Ozziemoe was over and we did some kick ass work. Put a serious dent in the project. See the light at the end.
Whats left...
Figure out a pressure line on the p/s.
Plumb all the brakes
Replace tcase
Build drive shafts
Mount rear shocks
Then hope it all works out in the end :sonicjay:
29 hrs into the project so far.
must be nice :thefinger:
Got the 1354M tcase installed tonight and the front driveshaft as well. Need to shorten a shaft here that I have to make the rear fit. Getting close.
Man you guys are moving fast! What steering box is that out of?
You're making me wish I built an expo now :icon_twisted:
I would have to say a IFS toyota
