just a thought about front brakes
rangerboy92
i was wondering . with so many different vehclies that used the twin i beam front suspsion. one would think there would be parts that should be interchangable. i am asking does any one know if there is a way to run a spindul off a f-150 on a ranger using the ranger i beams. Or does someone know what vehicule would . I ask about the f-150 because if you can make them fit the ranger you could run the stock larger breaks or any number of after market combos
There are some threads and articles on putting d-44 spindles on d-35 beams. I don't know about tib though. Use the search button.
Richard
Not unless you wanna fab a set of beams and get new wheels, drill out your rear axle bolt pattern or swap a 150 axle. It's been done, but mostly for snout strength not the bigger brakes, though that's an added benifit. Rangers are light though, put a set of ebc pads on it and call it a day, they make a difference from what I hear.
