just a quick question
stuartjohng
Charlottetown, PE, Cananda
Looking to do some mods to my 95 Ranger XL short box, 2.3L auto. Truck is stock at the moment. Very little money to spend but want the most from the truck. :icon_confused: Any suggestions? Like 14's to 15's. air restrictions, exhaust, spark or timing.
Welcome to the forums! Are you interested (or is it in your price range) to either lift or lower the truck? Body lifts are pretty cheap if you want to go that route, but then you kinda need to get bigger tires to make the truck look more proportional.
An overhead console (OHC) from an explorer is also a cool mod quite a few people do.
Hope some if this helps!
Well, going from 14's to 15's is gonna mean you need new tires and not really help too many things too much.
The Ranger's factory intake systems are pretty awesome, so that won't help you much either.
Exhausts are always fun to do. If you can come up with something for that I'd do it.
As for spark and timing, spark system is also pretty good, and timing on your truck isn't adjustable, not that I'd recommend timing as a mod. That would probably cause more problems than anything else.
Take a look around the forum. Particularly comb through some of the build threads to see what some guys are doing. When I first signed up I have only the vaguest of ideas about what I wanted to do with my truck. I started combing build threads and the library to see what had been done and came up with my final vision which is still in flux.
Newer badges and lighting stuff seem to be relatively cheap mods that a lot of guys do to make their trucks stand out.
Ditch the slushbox for an M5oD and you'll be happier with the 4-Banger!
and check your axle ratios on the door tag. anything numerically lower than 3.73 is going to cost you performance, especially with bigger tires. me, i'd go with 4.10's and the M5OD that hopman suggested. just my $.02.
