John Rudd, still learning TRS
4bye4
I have an 89 Ranger 4X4 extened cab, with a 2.9, automatic, and 250k on the vehicle. In cold weather, when I push the 4X4 button on the dash, the black box behind the left jump seat, 'clicks', and no 4X4. There is a white button on the top of the black box, when pushed, a red LED glows. I know there are 3 components in the system. I am looking for diagnostic starting points and pssible cures. Happy New Year to you>>>>>John
My old 92 4x4 did the same thing. I ended up replacing my shift motor and it fixed the problem.
Nevermind on the controller. If the LED Glows, it's in working order.
How do I respond to those that helped
Thanks to your suggestions, I know what I will be doing this weekend. I will post the results>>>>>John
The 4WD controller is working if you hear the relays click, and the LED flash (I think it was) 4 times when you push the white self-test button ('94 & down controllers).
If the LED glows steady, then the self-test failed.
You MUST unplug the two wiring connectors off the end of the controller for the test to work properly though (leaving it connected only by the pigtail connector).
