Jet Size Reccomendations?
1984ranger28
Davison, Michigan
Hi, a previous owner has removed the smog pump, the EGR, and made a dual exhaust with just cherry bombs. When accelerating, there seems to be no difference between 1/2 throttle and full throttle. So any suggestions for the jet size? Thanks, Lucas.
Is it cable linkage? If so you can get rid of cable stretch by adding a few small zip ties to the cable end. Google cable zip tie mod.
Once the throttle plates are open far enough to flow as much air as the engine is capable of drawing at that rpm, opening them further won't do anything. Depending on what carb you have and what rpm range you are focusing on it might not be a jetting issue.
