Jacobs ignition systems
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
OTOTM Winner
Solid Axle Swap
Nevada
6”
Who's using them or has used them? What's your opinion on them?
not worth the price unless your using plus four or some other exotic plug.
that is on a stock engine.
you have cranked up comp ratio or forced induction combined with a good aftermarket box on carb applications go real good.
Agreed. Forced induction will be the only reason I upgrade the ignition. My buddy actually met a guy at the track over the weekend running a 9 lb. Vortech with stock ignition that was running 12's all night long. Car was a 91 Fox Notch.
I acquired a mileage master and ultra coil several years back. I hooked it up to my 5.0 in my ranger. It runs good. I was wondering if they're supposed to be motor specific. For example V6 or V8 models. I tried looking it up but couldn't find much info other than the new models. I used a wiring diagram for one of those to figure out the wiring for the one I have. It was on a 2.9 when I bought a Bll back in 04. I havnt had any issues with it do far but if they're known for going out I'll take it off.
I have had a few.They do work for awhile.Then burn out.I am done with them.
I have a couple in non-RBV in use for decades, they are all older ones (not Mr.Gasket or who ever bought the name).
That box & coil don't care how many cylinders you have.
Oh sweet! You wouldn't know how to hook up a tach to it would you?
Any tach hooks up to the negative side of the coil (switching signal).
I've tried that. It reads 2500 rpm's while at a idle then when I rev the motor up it drops to 2000. I read somewhere that some ignition systems need a resistor installed for the tach but now I can't find it or anything else that says it.
Are you useing the factory tach or aftermarket?
A after market one. I think it's a Sunpro? It has a switch in the back for 4, 6,8 cyl but it doesn't seem to be reading right. I'm kinda frustrated with it cuz I'm not sure what to do.
