- Nov 27, 2008
- central IL
- State - Country
- IL - USA
- Drive
- 2WD
- Automatic
- Total Lift
- 6+3
- Tire Size
- 33/12.50/15
You could start out cheap, 15" rims 235/75/15 tires and then go from there. If you have 14" tires and switch to 15" you will want 4.10 gears but 373 will work kinda. you can check door to find out what gears you have now. You have to replace stuff as it wears out so look for used rims from explorers, rangers, mountianeer, some jeeps, some dodges. If they have good tires you can save from paying alot up front. I swaped rearend, then got 15" rims with tires 60. bucks. They work from a mountianeer. If your on that tight of a buget dont buy stuff you cant use as a dd. 31 are nice but you may wear out a set of tires before you get that far??? It is your decision on what works for you, its nice to go out and have truck start up every time. If it dont a 400. stereo wont help.
