I've read it all, it still don't help!!!!!!! clutch problems
rls89
citrus county, fl.
Cant get slave cylinder off. It goes into the side of bell housing, can't tell how it's held in there. Looks like some kind of pin should be there but it's not. On top of where the slave plugs in it looks like a pin should be there, but not. Don't have the stuff to take out trans. or I would. I have did everthing I have read about bleeding the system, but no luck. Still have no clutch when running. Drove truck one day, parked it, no clutch next morning. Low on fluid, put some in and tried to bleed. Thought i had clutch pressure a couple of times but went away. Need some ideas on what to do!!!!!!!!!:shok::shok:
Just did my 87, replaced with a rebuilt trans. Had to take bolts out and remove cylnder from the fire wall to keep from cutting the line. I have the Toyo Koygo 5-Speed trans. Removed from the trans after taking out the throw out bearing.
All 85 and later transmissions the slave cylinder is internal and the trans needs to be removed to change it. There should be a fairly obvious bleeder screw next to the line that goes into the slave cylinder.
getimage.php
