Because I have this:
(Comp Cam kit *Cam, double roller timing chain/gears, Roller Lifters, valve springs, retainers, valve seals*, ProForm Roller Rockers, rear spring hangers, front end links)
8PSI Supercharger pulley (up from 5)
Colder spark plugs
Transmission hard-lines (currently using ghetto rubber hose)
Roll Pan
head gaskets
valve cover gaskets
exhaust manifold gaskets
intake manifold gaskets
water pump gasket
timing cover gaskets
oil pan gasket
trans pan gasket
trans filter
3.55 rear gear and rear end rebuild kit
tall valve covers
Cowl hood
98 Mountaineer front bumper
High-side fan relay (Only setup on low side at the moment)
Into my truck:
Don't have any space to do any of the work until the end of the month.... REALLY don't want to wait that long........
Colder spark plugs
Roll Pan
head gaskets
valve cover gaskets
water pump gasket
oil pan gasket
trans pan gasket
trans filter
tall valve covers
Cowl hood
Into my truck:
