John Smith
- Jan 17, 2010
It's Alive..A successfull "Duraspark conversion"
I know many have done this but since i have posted some about this new-2 me 84" B2 I thought i would give an update even a visual one that maybe a new user could benefit from as well. I decide to put the "module" on the passenger side, and retain the stock coil location "as was"..and it made for a quick wiring job once i decided which way to go. I appreciate the input of the 2.8 specialists here who gave input. I was fortunate to have in my collection of stuff an 86" diz/ecm harness from a 2.3L that was very long so I put the ecm on the passenger side (and grounded it well) where there was a lot of room and ran my wires across the motor like it did from the factory harness and cut the old harness accordingly so I had a minimum amount of soldering and splicing. Also if I DO drop a 2.3 in here..the diz harness will be just right as well...
(I should also say that i had purchased a diz from a 78 Ford Pinto/Mustang II that i found locally and used the typical "cap adapter and cap" listed in the tech library) Installing it was typical and w/o drama being familiar with this procedure from prior experience. I WILL say it helped for me to make a mark on the firewall where the TFI rotor was pointing to b4 removing the stock diz at TDC-#1...
I'm not sure what my timing is set at..I just put the rotor point at approx the same position for Number one (1) to catch a wire I liked and gave myself room to move around a little. after plugging all the vacuum holes on the stock 84 2150A..it fired right up...
side note: I don't currently own a timing lite right now I know it's not kewl but for me if ur gonna "duraspark it" why get so technical...(this is just one step better than a set of points u know that don't you?)...so i just have decided to wait till i can afford a decent one or find one at a garage sale...(I like old school)...this is just a hobby anyway right?...
My strategy for timing at this point is to advance it for fastest idle...and see how it starts..when I give it a road test if I hear any issues at all I'll back it off a little maybe we'll see..(when i get the the new/old carb ready to put on I'll dig out the vacuum gauge and fine tune everything).
http://classicinlines.com/Vacuum.asp
http://www.fordmuscleforums.com/all-ford-techboard/411958-adjusting-2100-autolite.html
On my 55' Ford I used to set the timing where it would run smooth yet start easy on the gas I was burning..we'll see how that strategy works...(This reminds me of what I like about carbs..you can always tune it better as you drive it..but at least it fires up..sometimes UNLIKE an EFI powered vehicle..)
I'll get some parts ordered for this old 2100 I have now and see if I can improve anything..it runs great now though..thanks again all..
