2.3L ('02-'11) Issue After Engine Rebuild
Franklin
IN - USA
Vehicle
Drive
Struggling trying to get my 2001 2.3 L Ranger 2wd XLT going again after an engine rebuild. The truck was running fine before, just burning oil so we did a full engine rebuild and when reinstalling it I changed the fuel injectors, oxygen sensors, all of the hoses and belts and most other sensors. It started fine, but when I am accelerating hard it knocks - reminds me of pre-ignition spark knock like when ignition timing was off on cars back in the 70s. It gets worse as it heats up. With the hood open it sounds like it is resonating from the top of the intake runner manifold but it that might just be where it bounces off and sounds loudest.
A couple other odd things. When driving at a steady speed it sometimes feels like it is surging. I had driven it at low speeds below 50 on country roads up to the next interstate exchange and except for the rattle when accelerating, it semed ok. Then I got on the interstate and headed back to the shop and put the cruise on 70 mph and after a mile or so it started slowing down to 65, then 60 and wouldn't hold speed. Temps were fine, felt like it was fuel related - either starving or loading up. Took the cruise off and stayed around 60 for the next mile until the exit and it was ok. It never died though idle was erratic a few times.
I had changed the crank position sensor and thought maybe that was off a little and the computer trying to over correct and causing the spark knock sound. Double checked that and it was in the right position so not that.
So, wondering if any of this sounds familiar to anyone here. My gut says it is fuel or timing related and one of the new sensors is bad and the computer is confused and trying to compensate. Not sure is the MAF sensor might be a potential issue as it does control the mixture, or some other sensor.
Again, if you've ever run across a similar issue with knocking on accelerating like the engine was too lean and spark knocking and you found the cause, I'd appreciate any ideas. Thanks !
what do the spark plugs look like? oily? super white?
check the fuel pressure and cylinder head temp.
dual overhead cam Duratec engine, right?
Thanks - and sorry, this is the Mazda engine.
Cylinder head temp was fine using a hand held light temp gun, as was the rest of the engine/no areas abnormally hot, antifreeze levels looked good and it behaved normally as it came to temp. Plugs were new and it only has maybe 25 miles on it in several drives but was planning to check those when I check the fuel pressure waiting to borrow a gauge.
clarification, what does the cylinder head temp sensor read?
need a scan tool for that.
I'd be leaning towards fuel issues.
60-65 psi
does the tank hiss when the cap is loosened?
being curious, getting back to your reason for the rebuild, using oil. how many miles were on it? all 4 cylinders fouling or just one or two?
my 2005 started using oil around the 250,000 mark, by the time I pulled it at 370,000, compression in #1 was down to 80-90 psi. 2,3,4 were still perfect.
Thanks - I'll check the temp with my scanner and pressure when I borrow a gauge.
As for the history, I bought the truck from a friend who got it for his son for his 16th birthday. The kid drove it hard and it had a rod knocking at about 150,000 miles. It was in great shape before then as a neighbor's garage kept commuter truck all of it life before.
I bought it and we rebuilt it then and it went about another 60,000 miles until one of the plastic conectors on a water line cracked and my son ran it out of water late one night on his way home from the night shift 50 miles away.
It was going through a quart every 1000 miles and he drove it that way for almost 40,000 more miles so it has about 250k miles now. It started knocking (like another rod) and we found there were damaged piston rings and other signs it had been really hot once we opened it up.
Same friend who rebuilt it before (he builds race car engines) went through it thoroughly - installed larger pistons, bearings and he had issues finding rod bolts but finally found some across the country and got it all back.
The truck has been sitting almost a year from when parked until I got the engine back in - he did it for free on the side as we are lifelong friends and traded favors for closed to 50 years. It had been running just fine as far as fuel mixture and computer controls before it sat. There had been engine lights on for the last year related to an intake runner leak error I never could find which was also a reason I changed as many sensors as possible and all the hoses, Ironically, no engine light now and those codes are gone.
My gut was something with timing or fuel as the last time I felt similar was back in the days before computers and fuel injection took over. The spark knock on acceleration that gets worse when hot reminded me of pre-ignition situations back then. I'm going to continue looking at fuel since the crank sensor seems to be spot on and there is no signs/misfire codes.
Rebuild... Cam timing off by a tooth? Maybe even just a half if the head was milled?
not on this engine, there are no timing marks or alignment keys.
you set the crank against a stop bolt & place a 5mm plate thru the slots in the cams then tighten it all down.
diamond impregnated washers lock the crank & cams in place.
the tensioner takes up any slack in the chain.
