Iso best cost effective way to level my 2wd
Nick Noble
Illinois
Im looking for what everyone recommends for a decent 2in level on these 2wds im also doong shocks any suggestions? I seen this “SKYJACKER 1.5-2″ SUSPENSION LIFT KIT WITH COILS AND HYDRO SHOCKS FOR 1983-1997 FORD RANGER” is this any good? I also seen some other options like taller struts
I would not do it. Affects the alignment and tire wear. What about lowering the rear? That will affect your caster, but maybe not enough to notice.
^True that anything done to the front will need alignment afterwards.
Might be able to get some spacer under the coil springs for about 1.5. SkyJacker is pretty good stuff. From what I've seen here 132 or 132x springs is common for 2" lift in the front. Any more than that and it probably won't be align-able without brackets...
Im fine with doing alignment. Instead of the coil spacers what about taller spings? Or will i need to find custom shocks?
Taller springs is the Skyjacker 132 or 132x. I'm sure there are other options I'm not familiar with. Those are very common.
If you're lucky, you might not need different shocks, but some manufactures offer what they call 0-2 in lift shocks. I have a set of Rough Country on the front now.
