exbass94
- Aug 6, 2007
- Age
- 37
- Guilford, CT
- Automatic
Today I was underneath the Explorer trying to get the damn front diff plug loose so I could check the fluid, and I grabbed onto the driver's side tie rod for support. I noticed that if I wrap my hand around it and twist, I can rotate the whole link back and forth roughly 20 degrees. (10 degrees each way) It looks like there's play in the ball joint that connects it to the drag link, as well as play where the tie rod connects to the knuckle. (I think I'm using the right terminology for the parts?) Anyway, should there be some movement so the suspension can articulate, or is this too sloppy?
