Is this a bunch of bs?
Total bull. Don't waste your time.
I found a real super charger that im interested in, just that came up when i was searching for it. They have a chip that makes 70 hp lmao.
it is bs, i bought one before i knew better and came with a chip but nothing worked right and the blower i still have and use on one of my cars and does sorta help out at WOT. but not worth the money
Something like 1/3 of the heat your fuel makes when you burn it goes out of the tailpipe. Maybe 40% goes into the radiator and the remaining bit is converted into rotating the crankshaft.
A turbo is about 33% efficient at making work out of the exhaust gas that goes through it. So a turbocharged engine that makes 200hp (a turbocharged 3.0, say) at the crank is sending 220hp worth of waste heat through the turbine of the turbo--and 70hp is being used to drive the compressor.
You ever see a 70hp electric motor? It weighs 143#. THAT motor would work. And it only draw 435amps. That tiny little shitty plastic bathroom vent fan doesn't quite seem up to the job to me.
lol most likely to cause restriction then later when one of the plastic blades come off and go down your intake your looking at major future Engine problums!
+1 on the air restriction. Over on the Tacoma forums somebody did a dyno test and I think lost almost 10hp.
the saying goes... if it sounds too good to be true, it probably is. Electric superchargers don't work.
Sadly, people buy into this.
