JoeVR5
- Oct 17, 2008
Is there a way to pull out the bedliner without removing my tonneau cover? I've never removed either in 10 years.
It's an ARE fiberglass cover with a spoiler on the back. I'd prefer not to remove it, but I'm thinking I will have to do that to get the bedliner out.....
Is there a way that I could loosen the bolts underneath the bed without pulling them all the way through the other side?
If all goes well, it should be a quick on-and-off procedure, and I could just lift the bed off the frame and set it on some blanketed 2x4's before fixing the filler neck and reinstalling the bed.
Is that possible? Or are the bolts installed from the top?
