JoeVR5
- Oct 17, 2008
Hi all,
I'm brand new to the forum, and I was wondering if anyone can help me out with a small problem that has turned into a VERY expensive one.
I have a 1997 Ranger Splash, 2wd, 4.0L Ext Cab, 5spd. It has been an AWESOME truck, and I've had it for almost 10 years now.
About a year ago, I started to have a problem filling my truck with gas. I couldn't pump it any faster than about 2 gallons a minute or it would back up and overflow.
I took it to a shop and without even warning me, it wound up costing $600. Apparently, the filler neck on the 97 Ranger splash is a dealer-only part and it is over $350. Holy Cow!!
The problem is, the new super-expensive hose has now made my fuel-filling problem is WORSE! I can't gas up my truck any faster than a gallon or so per minute or else the pump backs up and spills fuel all down the side of my truck. This happens OFTEN. I cannot even set the gas pump on the first notch. It's VERY frustrating.
I looked under the truck, and it really looks like the hose is completely collapsed. I took it back to the shop and they said that all rangers with the flaresides have this problem because there is a sharper angle going into the tank, and you really can't fill it with fuel at a normal rate.
I have trouble believing that because for the last 8 years, I had NO problems filling it with fuel. Now it takes me almost 10 minutes to gas up my truck.
I took it to another shop, and they tried to put a metal sleeve around the collapsed hose, and hose-clamp the sleeve to try and get the rubber hose to open up a little bit, but that didn't work at all.
I'm REALLY frustrated at this problem, because I have to budget serious time for gassing up my truck. I DON'T want to spend another $350.
Had anyone else had any problems like this? Are there any solutions that won't cost me an arm and a leg?
Any help would be GREATLY appreciated. Thanks all!
