I doubt its compressor related, although I wouldn't rule it out totally. Does the A/C work normally otherwise, like if you're at road speed? If so, you could have other engine-related issues. For example, if the engine has low compression or low power, the A/C kicking in could cause the engine to stall at idle. One possible check you could do with the compressor, however, is to check the clutch hub for excessive resistance. With the engine off, try to rotate the center of the compressor pulley. If it binds in any fashion, you probably do have compressor issues. Just be sure not to confuse normal pressure from the refrigerant with actual mechanical binding. Hope that helps.
