Is Motorcraft Mercon V a good substitute for plain Mercon, can;t fine just Mercon for transmission?
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Motorcraft says Mercon V is compatable with Mercon fluid on oil container, so I ordered Mercon V for a trans. filter change,It's actually Dexron III/ Mercon but I agree. Ford power steering fluid and transfer case fluid meet the same specs and cost more so I buy Valvoline/ Napa Dexron III/ Mercon.
Been using Valvoline MaxLife FullSyn MerconLV in this 1354 TransferCase several years now.What is Dexron-VI , Mercon LV good for? Other than $10 Qt
LV= low viscosity aka liquid velvet. Dont use it.What is Dexron-VI , Mercon LV good for? Other than $10 Qt
If memory serves we fixed harsh reverse complaints by replacing valve body gaskets.My 94 Ranger 4.0 automatic shifts hard into reverse, and somewhat hard into drive, what would cause this as I have lowered idle speed but still have this problem.
For Mark's sake is that through-out or just the main (installation) gaskets? I am NOT well educated on automaticsIf memory serves we fixed harsh reverse complaints by replacing valve body gaskets.
Actually I don't know any other brands they have the but I was only looking at the Walmart store supertech brandBeen using Valvoline MaxLife FullSyn MerconLV in this 1354 TransferCase several years now.
My understanding is there was much confusion & many damaged 1354s
when Ford discontinued original Mercon & switched to MerconV for 4r\5r Transmissions.
Prefer MerconV FullSyn AmsOil\RedLine in this 5r55e & PowerSteering.
