Is it lifted ?
purecountry
I BOUGHT THIS TRUCK NOT TO LONG AGO AND NO ONE CAN TELL ME IF ITS LIFTED. THEIR IS NO BODY LIFT IN IT AS I HAVE CHECKED BUT IT IS SETTING ON 265/75/R15 AND IT DONT RUB. I SEEN ONE THE OTHER DAY WITH 235'S ON IT AND THE GUY SAID HE COULDNT GET A 265 ON HIS.
measure your coil springs, ill measure my stock ones to compare. also there should be a rear 2" block nothing bigger
Look at the rear leafs and if you see a small block between the bottom of the leaf and the axle, then you probably have a factory lift. (Usually 1") My truck had 31's stuffed under it with a factory lift when I bought it.
Didnt look at the rear but my front coils are 11 1/2 inches tall top to bottom
That looks like its an STX to me, they have an extra lift from the factory, does it say stx anywhere?
Stock coils meanusre in around the 10" mark. so if you get 11.5 then you likely have leveling coils. 91 won't have the Highrider lift. that was stopped in 89.
All 4x4 rangers run a 2" block out back. the 2wd's lack the block.
haha that reminds me of a story...a guy fail my truck for a state inspection because i had factory lift blocks....there so called ford expert said that no ford ever came stock with lift blocks....:icon_rofl: some people are just stupid
