- Apr 13, 2008
- Bellefontaine, Ohio
- Automatic
I think alot of it has to do with the size of the car. GM's Grand PRix and Monte Carlo were not too horrible to work on, had a 94 GP and a 96 Monte, both not too bad altho you had to remove the washer bottle and a body brace to change the battery in them. the 94 Olds 88 that I had was awesome. bought it in 02 with 58k on the clock, drove it to 08 and when I sold it it had 180k, on it, only major work I had done outside of maintenance was the MAF sensor went bad and nuked the computer with it. (I let the stealership fix that one to the tune of about 500 bucks) when I sold it the original a/c still worked, still ran great and drove great. CHanging spark plugs was easy, the worst part was pulling the boot off the plug. ( I dread doing the plugs in my 4.0 ranger, they look like a royal pain in the ass)
my 94 Dodge Intrepid while not as reliable as the Olds, has been super easy to work on too. again, a larger car. the only reason I sold the Olds and kept the Trep was the a/c didn't work on the Trep and the paint is peeling off the roof. it did have about 10k less miles on it in 08, but I figured I would get squat for a 14 year old car that looks like hell and has no working a/c... so I kept it and sold the olds.
the 09 Charger we have, got the lifetime warranty on it and I don't have to chase that one with a toolbox at alljust the maintenance items. the spark plugs don't look too horrible to get too.
The Ranger... a lot of things about the 4.0 to me for servicing are a pain. including that ford ran the plug wires under the upper intake manifold and how ford has the egr system running into the upper manifold. makes removing the manifold a pain.
after helping work on a friends 97 neon, you could not pay me to own one of hose POS's, but then again, I feel the same way about the cavelier as well. You want a car that is easy to work on, get a large one.
AJ
Man I can go for days on cavaliers When I ,meet my G/F she a sonic blue Z24 Although I can admit the 2.4 was a way better motor than the 2.2 that came in the normal cavs. Here clicky: http://therangerstation.com/forums/showthread.php?t=62224&highlight=finally+car
Not to mention the drivers door was falling of it's hinges you had to lift up and pull in to close it. Had to replace the door latch twice because of the missalinement. The tranny would get completly empty from fluids and start slipping, not any clue how it never had a tranny leak that I could see the motor burnd it for gas or something. So I was alway needing to put fliud it. Hay but atleast the spark plugs was easy to change. I hit two deers with it cause of the bad brakes, if someone stoped quickly you had to dive fr the left lane or the shoulder to keep from hitting them, even if you had a couple car lenghts.
