Is it a timing issue or a fuel issue?
Drewbis
Hey everyone, here is my issue... My 1996 Ranger 2.3, 2WD has about 105K on it. It runs fine, but this weekend I changed the timing belt, timing belt tensioner, serpantine belt, and thermostat (while I had it all off for the timing belt swap). I followed the Haynes instructions, everything went smoothly, but now the engine pings during high torque (lower RPM's) and goes away when I reach a cruising speed. Also, at idle, the engine kind of hick-ups. Sounds like it's misfiring. Runs smoothly when driving (aside from pinging), but when at idle, it will idle smoothly for the most part then misfire every so often. It may be worth mentioning that the misfire is much more pronounced when the engine is at normal operating temp.
I'm certain my timing marks are lined up, I checked them 30 times. When the crankshaft is at the "TC" mark, and oil pump and camshaft marks are spot on. Could it be that the tensioner is just too loose? I only allowed it to tighten to the spring loaded tension, but keep in mind the spring is 14 years old. Should I loosen the tensioner and pry it tighter onto the belt?
The only issues I had while changing everything was getting the crankshaft pully bolt off. I first tried wedging a prybar onto a crank cog that looked to be the light-sensor crank cog for the crankshaft. (Looked like a bike gear). I used that as a means to hold the crankshaft still while I loosened the bolt. It put a couple very small grooves in the cog. Would that throw off the light-timing?
Also I forgot to plug one of the spark plug boots back onto the spark plug and when I started the engine it arced for a minute on the exhaust manifold. Could that have maybe shorted the something in the ignition coil?
I doubt that either of the latter issues are the problem. I think it's a timing issue, but I'm a welder, not an auto mechanic. Any help would be greatly appreciated.
When in doubt, check the coil pack(s). A pack can start to fail, but not trigger a fail code and still cause random misfires. If the wire arced against the manifold, it could have caused an issue with the corresponding coil. Not saying it did, but its probably worth checking.
I think it's timing.
I just helped out another guy on the forum with a similar problem. And it stems fro the quote above. That "Bicycle gear" looking thing is the flag for the Crankshaft Position Sensor. It is not bolted to the vibration damper like you would think. It is pressed into the rubber that is part of the damper. More than likely when you put your pry bar on this to loosen your pulley bolt, you twisted the flag (or gear looking thingy) out of position. You could try to force it back, but I would recommend a new vibration damper from a junk yard.
Good luck.
Nothing is shorted, the timing marks will get you in the general area of proper timing, BUt you must still listen to the motor and make an adjustment one or two teeth whichever direction makes it run better. Wat I do is set my time, turn it on and listen, then if i need to I adjust it one tooth one way, if that dont work 2 teeth the other way( so im only one tooth past where I started, and one tooth at a time i adjust til it sounds right.(obviously turning it off for adjustments and then back on.)
