All 3.0 OHV Engines are essentially the same long block. These engines are known as the Vulcan 3.0. If you're using an engine from a fwd donor, switch upper and lower intakes, exhaust manifolds, and head gaskets to Ranger components.
Ford also made a DOHC 3.0 v6 known as the Duratec 3.0. It is completely different, and incompatible with the OHV Vulcan.
For
