CovingtonJim
- Oct 13, 2009
- Automatic
I inherited a 1984 Ford Ranger, V6, long bed, 4-wheel drive. It has 104K miles but has mostly set for the last 10 years (4K miles in that time, less than 10 over the last 3 years). A little rust, but not much (it has been inside), but now not running. I was told that the top end of the engine was redone at 99K miles – 10 years ago. I know that it needs, exhaust. a wiper motor and transmission pan gasket.
I am not a mechanic by any stretch, so about anything that needs to be done, will need to be done by a professional. I would like to put the truck back into service (both for need of a truck and sentimental reasons), but do not want to put “much” more into it than what it is worth.
I had it running after replacing the accelerator pump in the carburetor (which was leaking bad). It ran great and drove well. Later, it started running roughly. The next week, I added fresh gas thanking the gas in it was not great and it would not start. I may have flooded it badly or something else bad may have happend. You can hear it fire once every 100 revolutions, but that is it.
Questions: (1) Is it worth trying to replace the plugs, wires and cap (which does not look like any fun), or should I just have it towed to some place that knows what they are doing? I have flooded lawn mowers before to where a plug replacement was required, but 6 plugs?? (2) The floor shift does not seem to line up with the notches for Park, reverse and drive. Simple adjustment, or transmission problem. (3) What is the thing worth running, so I have a top end for the amount to put into repairs?
