interchangable parts list
A list of vehicles that the manual steering box comes in. Copied from E-bay seller;
FORD F100 PICKUP 83 Manual Steering; from 3/83 (tag SMK-C)
FORD F150 PICKUP 83 Manual Steering; from 3/83 (tag SMK-C)
FORD F150 PICKUP 84-90 Manual Steering
FORD F250 PICKUP 83 Manual Steering; from 3/83 (tag SMK-C)
FORD F250 PICKUP 84-90 Manual Steering
FORD F350 PICKUP 83 Manual Steering; from 3/83 (tag SMK-C)
FORD F350 PICKUP 84-90 Manual Steering
FORD VAN 02 Manual Steering; (E450), w/o ch cab
FORD VAN 83 Manual Steering; from 3/83 (tag SMK-C)
FORD VAN 84-90 Manual Steering; tag SMK-C
MAZDA B-2300 94-97 Manual Steering
RANGER 83-85 Manual Steering; 4x2
RANGER 85 Manual Steering; 4x4, from 11/84
RANGER 86-97 Manual Steering
Does any one know what power steering pump pulleys interchange with the 83 ranger 2.8. Sorry looked online and at the local parts stores and couldn't find one that would work. Sorry if this is in the wrong forum. Thanks for all the help.
The M5OD bolts into place of the A4LD and FM146 as long as the number of cylinders on the donor and recipient match.
No they won't....3.0 and 4.0 have same number of cylinders (6) but are not interchangable. Also the Duratec 4 cyls have a different bolt pattern from the Lima 4 cyls.
+1, I wish things were as simple as count the cylinders and swap, but it just wouldnt be a ford then.
This sounds like a good idea! bump! it'd really simplify alot of things
Just search for it. The question has be asked way more times than I can remember.
Though it's pretty simple, If it looks the same, it'll probably fit.
But one thing most don't know is all the body mounts are in the same places on all of em. Meaning, a 2010 body will bolt up to a 83 chassis.
Just search it. It's all there.
And any truely comprehensive answer to this question would start to look like the manhattan yellow pages, two THICK volumes, thin paper and tiny print...
AD
What about body parts between the explorer/b2300 and the ranger? My ranger grill/headlights are busted, will explorer or B2 fit, or do I have to switch the fenders/doors as well?
The whole point of this would be to make something organized, and include information that hasn't been asked. Alot of the times I search for an interchange, its something that hasn't been asked. There are ALOT of grey areas for part interchangability.
i got a few.
mirrors will interchange between 93-05 (non power) 06+ will fit with minor mods.
tail lights will interchange from 93-99. 00+ will fit but will require minor mods.
window cranks will interchange from 93-11
beds will interchange from 93-11(long bed, short bed, flare sides)
rear bumpers will interchange between 93-11(chrome, painted, basic model bumpers)
Thanks for the info on the body parts that interchange Honduras! Nice new profile pic btw.
It would almost behoove us to build it into a database. Something simple and searchable.
I don't know about the 2.8, 3.0, or 4.0 cause i've never owned any of those but the 2.0, 2.3 and 2.9 all share the same starter solenoid and ignition coil with the 5.0 (302), and 5.8 (351).
interchangable door panales for 2011 ranger and 2008 b4000 truck
can you please find out if 2011 ford ranger door panels can be interchanged with Mazda b4000 2008 doors.
I have built 2 gen 3's (93 & 94) and am workin on 2 more (94 & 95), so I will tell what I have found within these builds, but if you need to know other info, I have the ability to check via Ford catalogin at work:
93-97 fenders, hood, front bumper, grill, headlights, marker lights are a direct swap.
93-94 radiator supports are same and 95-97 are same (2 different PN's)
93-97 doors interchange
93 to 08 beds are direct bolt ons and taillights are interchangeable
92-02 Explorer rearends are direct bolt-in if you want 4" of drop in the rear, if don't want the drop, then you have to weld on new leaf spring perches
92-02 Explorer seats will bolt right in after you swap the Ranger tracks to them, the Explorer seats have the holes made into them for the tracks
93-97 cabs are interchangeable, as are 98 up
82-97 steerin boxes are interchangeable to include the MS boxes
82-94 heater boxes interchange, as does 95-97
I'm sure I'll think of more, but that's all I can think of for now!:icon_confused:
ummm yeah, all interior pieces essentially interchange 96-current, styling might be a little different, but they'll all fit the same.
