Duane867
I have a 93 2wd 5spd 2.3L.
I bought it with an after market tach already installed and I think its wiring is causing problems. At 1st the instrument panels lights would come on and off when the lights were on ( well one side of the cluster any how ). As I played with the tach wires I noticed that the movement effected half of the instrument cluster lighting ( the left half ).
SO I embarked on removing the cluster. I was stopped abruptly after removing the panel below the steering column. I can see no way to remove the radio, heater AC bezel or the bezel around the instrument cluster in order to remove the cluster its self to check the wiring.
How do I do it fellas ?
