Instrument Panel 1983 Through 1989
ronclark
Ham Radio Operator
GMRS Radio License
Woodland, WA
Does anyone have a the wire diagrams for the instrument panel 1983 to 1989?
the link the the Tech Library is broken:icon_surprised:
I recently swapped the cluster in my 84, I have diagrams. The wiring color codes are the same for those years. What did you want to know?
well i am doing a 4.0 swap and i was looking for the wires so i can hoke up the temp,oil,idiot lights,etc
The red/white is the temp, the white/red is the oil, pink/white parking brake, light green/red to alt. warning light in from charging system, red/light green from alt. warning light out to fuse panel & ign. switch, dark green/light green seat belt indicator, yellow/ white fuel gauge, light blue 4wd indicator, black/light green solid resitance wire instrument voltage regulator, green antilock, grey check oil, red/yellow fuse panel, green/yellow tach, black/yellow tach ground. That's the bulk of it I may have missed a couple, hope that helps.
Thanks.
Do you know if the colors continual out to the driver side wheel well?
