you can not easily fit 35 spline axles, you can go 30 spline though which is huge.......theres allot of ways to go bigger with a d44. pro and con are dictated by end use for the most part. i was busting internally with the d35 more often then anywhere else at the end. the d35 is not equal to a 44 in axle shaft strength by a large margin.
I had 2 sets of Skyjacker braided lines fail on me.
That looks a lot better
I've been running Skyjacker's hoses for over 15 years now, never once have had an issue (but I have had issues with Procomp's and one other's... Superlift's maybe but not sure). The SJ hoses appear to be made from far better quality materials too.
Were they maybe the very early SJ hoses that had the banjo fittings at the wrong angle for the hose to have proper slack? (you had to grind a corner down for it to fit correct)?
I'm not entirely sure what you're getting at there (mr meagi isn't ringing a bell for me), but no doubt I do always try to do things the correct way (or at least in such a way shit's not gonna come apart on me).dude....your the mr meagi(dont know how to spell that right) of superhero fix shadetree wheelin. i remind myself i always run with v8 power liberally and usually ignorantly applied just for the noise of it...and simply offer a different point of view on that premise alone.
I have thought of reusing my D-28 radius arms due to the '85 swap bar/shock mount I am familiar with. If i want I can get 2 brand new arms (1997 factory stock) for $65 each, and build the complete assembly while driving the D-28. The shock mounts different and the sway bar mounts it do not look to be retrofitted in...
Opinions?
