installing cruise???
harleytech
palatka, fl. jax.
Anyone know how hard it is or would be to install cruise control into a 96 mazda... all the wiring should already be in place right?
bumping because this is something i might be interested in doing also
How would cruise control work on a Manual?
I have an 89 F-150 manual with Cruise control, but I have never dared touch it. I think I only tried to use it once, but I had it on 5th gear by the time I decided to engage cruise control. What happens when you want to go faster and you shift. Does it turn automatically off?
Pushing the clutch in will turn it off. Cruise works just fine on a manual trans vehicle. I've had it on several.
Bump because I'm curious for my 91 (a/t). I've got the steering wheel cover with the buttons off an X, but none of the rest of the componants...
Aftermarket Cruise Control kits are a piece of cake to install. Takes 4 hours or less if you have never done one. I have done 3 and they work every bit as well as OEM. They work on practically everything but a Honda. They have an overspeed feature so they are fine on a stick; push in clutch, engine revs, cruise disengages. The last one I bought was about $200.00. It was an Audiovox and their Help line is second to none; they take calls and know their product inside and out. I can see how troubleshooting one from another vehicle could be a pain since there could be obscure differences between vehicles. You will not find help as is available with an Aftermarket.
