montejw360
- Jun 7, 2008
- Automatic
Hi, new to the board. I just installed an Audiovox cruise unit in my '99 2.5 L 5 speed Ranger. Sort of works. Brakes take either a long tap, or a double tap to shut it off, have to pay attention to that and figure it out. It won't shut down when the clutch is depressed. It's supposed to pick up the engine rev's and shut down after 500 - 700 rpm increase, doesn't do it. Using a Haynes manual I "found" the tach wire and VSS wire, both were the color stated in the manual and at the pin number stated in the manual. 48 for the Tach, 58 for the VSS.
I also have a weird pulsing in the steering now. The engine seems to be missing, sort of, but in a weird way that I've never seen. Not like one cylinder is dead, something that I can't figure out. Something is messing with the electronic ignition I'm sure, but can't get a handle on it.
I'll drive it and see if it smooths out. The Haynes book says if the PCM is removed it might take a while for it to regain it's settings, something to do with adaptive engine control.
If you have any ideas, let me know, thanks.
Monte
Monte
