Hi guys,
Is there anything tricky or problematic with changing the inner tie rod ends on a 2000 2wd ranger? I couldn't seem to find anything in a search.
No there shouldn't be.Unbolt the sleeve that holds the inner and outer together.Take off the cooter pin and nut that hold it to the linkage and use a pickle fork to remove it. then just unscrew out of the sleeve need to count number of turns and put the new back in same amount.
For
