injector size
88BII
Florida
1985
what cc are the 2.9 injectors, just curious.
will 4.0 injectors drop right in or is the impedance different?
they should drop in, but your computer isnt tuned for them...you'll run incredably rich.
why are you trying to upgrade your injectors? you know the stockers will support roughly 160hp....20hp over stock. and if you bumped your fuel pressure up a bit they could probably reach close to 200hp.
Hello
Grey is 15lbs, orange is 19lbs and red I think is 24lbs. Make sure you keep them the same color that came out. If you put in a 19lbs in a 15lbs motor it will run like crap and very rich. Now if you want to run 19lbs injectors on a 15lbs computer you need to recal your maf for it or have your ecm reprogrammed.
igiveup
its a 2.9...no MAF :icon_thumby:
tuning an EEC-IV vehicle isnt the easiest task in the world...but it can be done.
how exactly do you tune an EEC-IV vehicle?
you need to have a chip burnt to your exact specifications and plugged into your PCM's j-port. SCT makes EEC-IV chips if i recall. doug at bamachips could also probably program a custom chip for you.
the SHO guys us the twEECer...while ive never heard of it used in a ranger, i dont see why it wouldnt work in any EEC-IV vehicle. the twEECer is kind of a piggyback thing...thousands of times more useful and tunable than just a chip.
its a 2.9...no MAF
90' MAF computer is pretty easy to adapt in an '88 though..
Did run 19lbs injectors w/ IST Air Adjuster, ran good above 2,500 rpm, pretty rich at idle. Eventually I got flow matched stock from Fred at Rogue Performance when they started ticking (used) and I started pieceing my V8 swap. Actually came w/ a chart on the flow tests.
I have a cam and other mods though, definitely not good for anything close to stock. Only went w/ the MAF computer because the sd/map computer wouldn't have liked the cam at all..
Pete
