Injector replacement???
Space_Ranger
Florida
So about a few weeks ago, I finally had a chance to hook up my 2005 Ranger V6 3.0 to a scan tool. Found out my cylinder 4 was misfiring. I changed the spark plugs, wires and coil pack. Yet it had still misfired. I bought the injector for it. although i have not found any helpful videos or tutorials on how to remove and install. If anybody can give me either a diagram or some kind of guidance. Do i have to take anything off to replace the injector????
Do a compression test first.
To get to the injectors you have to remove the intake manifold, hardly a daunting process, but it will require new gaskets.
I hope it is the injector for you. I have the same problem and replaced all the same including the injector. Still have the same problem even when a shop told me my compression was good. Let me know how it goes on your end.
