Is there a problem with the engine running, or are you just playing around with a voltmeter and think you've found a problem?
The 12v + is always hot, the 12v - is only for a micro second while cranking and running, There is no real way to check the voltage using the 2 injector wires while running or cranking.
Thanks for the comeback greatly appreciated. Gotta a no start. Spray gas into intake starts and runs till fuel runs out. here's what I have done. Pulled upper intake
and removed fuel rail checked fuel flow by cranking engine over. Very weak flow pattern. Removed injectors and bench tested with carb spray and checked resistance on all injectors. Good flow pattern when bench tested.checked fuel pressure at fuel rail between 45 and 50 lbs no noticeable drop with engine cranking. I am pretty sure it's a ground problem. Wiring diagram shows pins 59 and 58 are injectors grounds at pcm. With injectors disconnected so no load on circuit I checked voltage at those pins and still shows very low voltage when cranking. it is getting the pip signal from the distributor to pcm just not enough juice to injectors. I really appreciate you guys for helping me out here. Jim
