Injector help!! Will they work????
Danno87
Bozeman, MT
So this weekend during the beginning of a 4.0 swap into my 87 b2, I had dropped a fuel injector. Shattered the spray tip and I don't think it can be used again. So after a bit of part research I found they aren't cheap and come in a few flavors. I found a whole set available for a good price. They are accel injectors 255cc/min 24lbs/hr @ 200$ will they work with a stock 4.0 ohv? Or are they designed for a supercharger & turbo setup??
I know there's someone out there that has installed these slightly bigger injectors that can help me out.... anyone out there?
Sent from my SAMSUNG-SM-G870A using Tapatalk
Would you trust ordering those through ebay?
Reason I ask ,is I have never ordered through ebay. Never trusted it.
I have never had a problem with e-bay. I have always gotten what I ordered.
However, as a backup, I use pay pal, so I have a fighting chance if I ever do have a problem.
Well. The seller look good. I think I'll give it a shot. Thanks for the link.
Does it matter that the seller chart says it's not compatible with 91 explorer?
I ordered that exact set for my truck. I have a 92 engine with 94 wiring/computer. I'm not really sure what the difference is for a 91, but if the parts thing says they don't fit then don't order those ones.
I have gotten a few sets of injectors off ebay for cheap and have never had a problem with them, except for the set that the post office sent to the right address in the wrong city. The only problem there was that they got sent to the wrong city.
I use E-bay a lot live in a small town not much here.I've had good luck and bought a lot of things for a good price.
Junkyard. Go pull a handful of injectors from a matching vehicle. Pennies on the dollar over new, and most if not all that I have used have not had issues.
Thank for the info guys! I'll go ahead and order a set. So I also have an off topic question. I am doing thisnswap and will not need ac. I found a doorman bypass bracket with poor results. Question is have any of you removed ac and used a smaller belt?
